bigkahuna427
- Joined
- Jul 14, 2011
- 52
I have been searching for a boat and found a 21' Bayliner Walk Around Cuddy Cabin. This is a 1983 Trophy with with the AQ131 aluminum head overhead cam closed cooling system engine. I just took a ride to see it and there was a lot I liked about it. First off let me say I am a mechanic.
What I could see under the deck and bilge area looked really solid as far as transom and stringers. It has stereo, garmin GPS, fish finder and I am told the trim tabs and stern drive lift work good as well as bilge and blower. The cuddly looked real dry with useable cushions in decent shape. The current owners used it in a fresh water river above the dam. Never been bottom painted and the outdrive looks like it has little salt water use.
This guy had quite a few repairs planned so has a bunch of parts. For the trailer he has all the u-bolts and fasteners, new springs, shackles, bushings, rollers. It is the heavy Load Rite galvanized trailer and looks good except for the parts he already has. The tires are weather cracked so it does need 4 new tires.
For the boat he has new stern drive bellows, water neck, raw water impeller and a few other things I cannot think of at the moment. The oil pan has some rusty scale on it and he has a replacement although he said it did not leak. It has been sitting for three years and currently has no spark. I am going down again this week to see if I can get it to run. I am hoping to connect the fuel pump to a can file the points an see it run, (hoping). The engine was winterized and fogged before putting up. The engine oil is brand new and does not even need a change. The antifreeze nice and green with no oil. The hour meter was at 1700 hours. I have in my head that maybe I can get it running after cleaning tank and carbs, new batteries and bilge. MAYBE do a trial run if there is not anything that is keeping me out of the water. On a slip or mooring I could get the trailer work done. Then pull the motor, oil pan, reseal, check bearings, oil pump maybe do a head gasket and certainly the timing belt. All easy stuff when in an engine stand.
I have done little research on this engine but am very familiar with it from the 1980s Volvo cars.
What are the inherent issues with this engine?
It has the 270 outdrive. Is this the correct one for this engine? What little research I have done most are AQ131 and 275 outdrive.
It probably puts out around 120 to 130HP seems like a small motor for a boat this sized. The owner and I did talk about speed and what it takes to keep it up on plane. He said it does need to be wound up pretty good to stay on plane. Any thought on fuel efficiency or speed and staying on plane at cruise for this combination?
The V near the transom is not as deep as I would like to see but this boat is a far far better value than the 1970s Grady Whites I have been looking at. It is priced very very reasonable for what is there. It is sort of a wife says it has to go situation. It has poor photos and description online. I thought I was going down to look at a scow but glad I went. I want to grab this before I get scooped. Please give me your thoughts!
