Another question from the house amatuer
PeninsulaPaul
Hello,
Paul here with my ongoing project.
I am looking into replacing the metal rails on my boat. Many of the mounts are cracked, pitted and basically worn out to the point they let the rail wiggle too much.
I have a set of rails on the upper deck that are square in shape, a set on the side of the boat that are straight and a set on the bow that are shaped like the bow of the boat.
I want to replace them with wood because a local marine salvage place has a bunch of them that I can cut to size (thanks to all who suggested the salvage place....WOW!)
What about the bow though? I had a carpenter friend tell me I could buy a wood rail and have it steam bent (not familiar with that) or he said I could just buy thinner pieces and assemble them together and epoxy them.
Has anyone made a curved wooden rail before?
Thanks as always!
jonesg
Re: Another question from the house amatuer
Bending laminated strips is suited to gentle curves, I did some wingtips for a piper cub like that, it works great.
PeninsulaPaul
Thanks Jones, this is an adventure to say the least..lol
Bifflefan
Steaming is out because you need a steamer box that is large enough to fit the whole piece in at once. While you can build it out of a piece of PVC pipe and a LP gas flame of some kind, its not something your going to use again and could be a expensive investment.
Laminating is a good idea but, the strips will be with the edge up and may not look good when finished.
Id go to a furniture maker and see if they have a set of knives in the profile you like, then have them cut it out of one piece of wood with the curve in it.
It will look a lot better.
PeninsulaPaul
Bifflefan,
Showing my ignorance here but "set of knives". I am not familiar with the term aside from cutlery. Thanks for the info and Semper Fi!
Woodonglass
An 8' piece of pvc pipe, 1 end cap, Towel, hot plate, tea kettle, heater hose. White Oak. Steam Bend it. If You can find a 16 foot long piece of white oak that is 1" x 1" then it CAN be done. Been there and done it!!!
I'm just sayin...:D
PeninsulaPaul
Woodonglass,
Thanks, I would really appreciate some more detailed instructions. Do you mind if I send you a list of questions?
Paul
jonesg
Glass it with 6 oz cloth/resin , paint it.
For me, I'd just buy a used stainless rail.
PeninsulaPaul
Bifflefan,
I thought of the edge facing up too but it would look really good if I were to use alternating shades of wood dark/light/dark and then epoxy them after gluing.
jonesg
Bifflefan,
But then you have to paint because epoxy has no UV protection, it will shrink and crack. Stainless is tough to beat.
Woodonglass
You can always send me a Private Message and I will be more than happy to answer any questions you might have. I been working with wood for over 40 years so I think I can speak from experience.
I'm just sayin...:D
