I just replaced the impeller on my 05 alpha one attached to a 4.3. It goes into forward fine, neutral...fine, reverse....not good. At first it wouldn't even go in and stalled the motor. Cranked her up again and she went in but with a lot of....not grinding but, I guess chattering. But I had to give it nearly half throttle to get it there and before it actually went into gear, the prop turned back and forth. When the lower is off I can turn the shifter and as long as it is in the full forward and full reverse position, everything is fine but if the shifter is moved just a little the prop will turn like in neutral. The shifter on the out drive...not the lower, has a little play in it which allows the shifter on the lower to move enough to come out of gear...I think.
Full disclosure: I just bought the boat and didn't put it in reverse before I started working on it. I did put it in forward and it was fine then. I don't know anything about working on boats but I'm pretty handy.
So, is the shifter on the out drive supposed to have "play" in it? Is the shifter on the lower supposed to be so sensitive? Did I do something wrong or do you think it was like this before and I was too stupid to put it in reverse before I bought it. I'm stuck. Please help...thanks.
