athiker
Thread starter- Joined
- May 9, 2007
- 33
At the risk of making this forum Smart Tabs central, it seems like the place to get some feedback.
I have a 2000 Cobalt 206 (21') w/ a 5.7L EFI 260 hp turning either a 3 blade 21p Merc Alum Black Max or a 4 blade 20p synthetic Piranha mounted on an Merc Alpha 1 Gen II sterndrive. I've seen the weight listed at 3,100 lbs but that sounds light to me. I've never had a hole shot issue with either prop, the SE 300 Hydro foil actually helped with porpoising and idle speed bow wander, but what I'm really after is holding plane at a lower speed. I can barely hang on just a touch under 20 mph. I have small kids that like to tube/ski but at low speeds. I'd also like to putter along sightseeing on plane at slower speeds. I really need to be doing about 25 mph to cruise nicely...30 feels closer to ideal. I top out w/ either prop just shy of 50 mph GPS and 4600-4700 rpm area. I spend almost no time anywhere near WOT.
So I'm looking for feedback from anyone with Smart Tabs and a similar if not the same boat. I'm also wondering what the right model is for me as my hp is a little over the specs of some.
Finally, as you can see from the pics, I believe due to my transom shape I won't be able to mount the tabs wide as is generally suggested. How will mounting them closer to the outdrive affect the expected benefits?
Thanks in advance...quite an active site here.
