dmoriarty51
Thread starter- Joined
- May 4, 2010
- 305
I've read over some of the threads about the aww over smart tabs and i ponder whether they are a good fit for me, so i ask you gods of the boating forum whaddaya think?
My boat is a 1995 Crestliner ProAM 1650, this is a 16ft 5in aluminum deep vee side console with a 70 HP Johnson 2 stroke for power. This boat seems to ride very tail heavy and will porpoise easily. It is not carrying water weight as its undergone a full tear out rebuild just recently. It also requires something on the order of 3800-4000 rpm to stay on plane, max rpm is listed at 5500 rpm and it will obtain that so I believe I am correctly propped. This is a fishing boat that I use mostly to ride around and hang out on the sandbars and beaches of the mighty Mississippi, very little actual fishin perhaps more as my 6yr old becomes more patient.
I currently use an SE200 hydrofoil on the motor which allows it to jump on plane but it creates a large fountain of water spraying up until I am trimmed up to nearly porpoiseing and didn?t help to lower plane speed/rpm much if at all. It did take out some of the wander at low speeds but thats not a huge concern to me
By Nauticus's the chart it looks like either ST980-40 or SX9510-40 should be the right fit.
So should I drop another $170 on the boat or let it be cuz well its just a little tinny.
