StratosVtRocket
Thread starter- Joined
- Jun 18, 2007
- 10
I have read and read and am still a little confused about this. First, I have a Johnson GT200 (88) j200stlccm. I had a boat dealer put a new water pump, rebuild carbs and install a water pressure gauge on it. While running it this weekend for the first time since working on it. The water pressure would not read at idle and would go to about 10-14 at wot. I looked to see where they hooked it up at and it was tee'd inbetween the small line going from the thermostats. I'm under the impression it should be hooked up at a scew plug in the adaptor plate. I found the screw plug. Is it the one located on the right side of motor facing motor from back of boat at the very bottom of the block almost against the cover? There is water coming out of the tale tell but it has always taken a few seconds before water starts coming out. I would appreciate some help. Pictures would be great. My camera is messed up.
