another water pump question
tav
i'm looking at the sierra pumps for 40 h.p 2 stk (2004) noticing they don't come with the housings (# 18-3394) is there a kit that does come with the housing or do you have to buy them separate? or where can I find that part # for the housing ? thinking I want to change the pump assy. thanks
ronward
Re: another water pump question
marine engine.com shows the housing, part #5031416 for $86.72. But it says out of stock. Other than that, I couldn't find the housing in a kit
Bob_VT
Do you need the plastic housing?? Yep, iboats does not list the housing did you break yours? Just order the whole kit and it has everything but the housing
In most cases a fresh impeller is all that is needed.
oldboat1
But if the housing is busted, it needs to be replaced. I have a couple of old ones (these are metal) that are chipped or otherwise can't be used. Damaged plastic ones are probably worse. You might try to locate a NOS unit on a shop shelf somewhere.
tav
no....nothings broke .....yet....lol didn't take it a part yet. just wanted to put a new kit in from housing to impeller. don't even know how the housing is .....i'm sure it's fine .
Many good water pump housings are thrown out.---------------Dealers prefer to install complete kits because-------When a bill shows $25 for parts and $100 to install folks complain.----When it shows $ 89 for parts and $100 to install they don't complain.
oldboat1
Yeah, probably means can't sell 'em or give them away either as a dealer, without getting into some kind of trouble. Hard not to get cynical over stuff like that, particularly if the parts are scarce or will get scarce (like that impeller housing, apparently). I know I've seen that kind of thing happen with car repairs I've had done, but then I probably didn't have any particular interest in the old parts that went away.
tav -- Don't bust it.
