cgrooves
Thread starter- Joined
- Aug 1, 2007
- 57
For starters: 305 V8 engine coupled with a Mercruiser Pre-Alpha Outdrive (Mercruiser 898, to be specific).
Symptom: Boat would not shift from neutral into reverse. It would try to engage, but you could hear gears start grinding and if you pulled the lever back further the RPM's would start increasing and it would never go into gear.
I let a marine mechanic attempt a simple cable adjustment, but ended up having to install a new lower shift cable because the old one was stretched beyond tolerance. Problem did not go away after the new cable was installed. Mechanic even made some adjustment at the remote and replaced cable linkage, to no avail. Mechanic stated that he would probably have to disassemble the outdrive and replace a 'shifting cam?' or something. Any ideas on what the problem may be?
