LakerRider
Thread starter- Joined
- Jul 23, 2010
- 10
I have a 18' boat that has anti-fouling paint on it. The paint has begun to flake off in areas and I'd like to totally remove it.
First question: What is the anti-fouling paint for? Is it used just for saltwater applications as I only use my boat in freshwater and trailer it each time. Do I really need it?
Second queston:
I've used a razor blade to carfully remove some of it. Using the razor blade just removes the anitfouling paint and does not damage the original gel coat underneath it. Whoever put the anti-fouling paint on did not use a good primer....to my advantage!
Can you please recommend a paint remover, stripper or solvent to help remove just the anti-fouling paint and not damage the under coating?
Second queston:
