Anti reverse spring
I am replacing the anti reverse spring on my 69 85hp johnson. I see on the points base there is a contac for the spring. My queston is does the coil part of the spring bump the contac or is that contac suppose to be in the coil of the spring? I think the contac bumps the coil on the spring, but want to be sure.<br />Thanks for your help!
Joe Reeves
Re: Anti reverse spring
Should the engine for any reason attempt to run backwards, that coil bumps into that contact which effectively interupts the ignition. Your line of thought is correct.
