Re: Anti-siphon valve
Amazing how many people don't have a clue how a tank is made or works, and why things are the way the are.
Actually Don, I have a bit of a clue seeing as how I personally completely dismantled my fuel delivery system including tank removal, pressure test, and reinstallation.
I am certainly no expert on boat and engine repair as I know you are by virtue of your posting quality, and I mean that in a serious, not sarcastic way, but I am learning to know my boat and on mine there aren't even any fuel lines below the level of the fuel like Big Keepers mentioned. I'm not sure how the fuel could siphon out without an antisiphon valve unless the fuel pump supply line was pushed down into the bottom of the bilge after it became disconnected.
If that occurred in an accident/collision/fire/whathaveyou then the fill and vent hoses could become disconnected/burn/break as well by nature of the force necessary to cause that supply hose to become loose/break/burn therefore leading to the same problem: fuel leakage/siphoning/spillage...danger.
I agree with you and Big Keepers that Aviator5 should probably pull his tank and make sure it doesn't have a bunch of debris in it.
Seriously though Don, thank you for all your postings. I've learned a lot through you sharing repair info.
