Antifreeze turned to gel
red.donzi
Purchased a boat recently that had been sitting on land, winterized, for nearly a year or so. Have run into issues with fresh water systems and head caused by the antifreeze sitting, which has turned gelatinous (sp?). I also think this has caused issues with heat/ac systems. Has anyone run into such issues and if so anything available that would safely break this matter down?
Thanks in advance for any help.
red.donzi
Re: Antifreeze turned to gel
Thanks for the information. Do you have any idea of ratio for flushing?
H20Rat
i've seen that happen with pink rv antifreeze. Some parts of the antifreeze can evaporate out, leaving the pink slime. As soon as it mixes with water it dissolves though, so it generally isn't an issue.
