antifreeze???
admjr33
my boat is still in the water til next weekend so last week i pulled the water feed hose from the transom, (bravo drive) and put a funnel in it and poured 5 gals of 50/50 antifreeze in while the motor ran. will this ensure that antifreeze is in all areas of the block and manifolds....i warmed up the engine to operating temp before i started this, if that matters
thanks
anthony
Don S
Re: antifreeze???
It won't insure anything but the manifolds and risers. Rather using muffs or pouring it in as you did it all does the same thing.
Read this thread for more info.
http://forums.iboats.com/showthread.php?t=280921
If you want to INSURE nothing freezes while it's still in the water, drain it.
Maclin
Re: antifreeze???
From the HazMat angle, did you use the Pink stuff or the Green stuff?
