FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
Hello i have a antique neptune outboard. I would like to get it running but first i have to know year,hp,and a place to get parts. the model # is (1181) and seral is (50359) any help would be appresciated. Thanks,Cade
A detailed description or a picturec would help.
Caille built A bargin line from 1917-1925 called Neptune.
There was also a Neptune from Muncie Gear Works comencing circa 1930
Most common was their 17lb 1.7 hp. I don't find your numbers associated with any of these though my info is very skimpy.
Oh sory the model number is (11b1) by muncie gear works. i have found some info but not much.1.5 hp,1941 and thats it. If anyone has any more info it would be appreciated. Thanks,Cade
EDIT: IIRC Doug Penn bought out all remaining Neptune parts stocks so give him a shout when you figure out what you need. He is a gentleman and a pleasure to do business with in my experience.
I need to know one more thing what to use in the lower unit. It says to use grease not oil ,and i dont know what kind grease to use. What grease to use?
Sorry, Bob's your uncle is Australian for...There you go! Trying to make a pun. Use Lubriplate 105 white engine assembly grease in that old Neptune's lower unit...check at auto parts stores. One tube will last you a long time.
