Re: Antisyphon valve bad?
You say the valve is flowing freely, so no problems there. Check this link to Don S sticky at the top of this forum, for possible causes of low WOT
http://forums.iboats.com/mercruiser...ives/list-possible-causes-low-wot-295070.html
Yes sir that's what I've been working off of.
New ethanol free fuel
Same prop as before when boat was operational
Antisyphon clear, apparently do not have a removable pick up line
Oil level checked, will be changed tomorrow
No growth
Same drive and ratio as before
Arrestor looks clean, does not change performance if removed. Will clean to make sure
How would I check exhaust flap? I exhaust moves through bellows and prop does this allow me to assume the flapper/shutters work correctly?
Will check compression..
Same carb.. May need a rebuild although one was just performed 2 years ago it coils be compromised due to the amount of filth in the fuel pump
Checking pump pressure and vacuum tomorrow
No over load
Engine temps good
How do I make sure my linkage is correct and that flappers open fully? Although boat was operational with same setup before.
All my problems are also under load. No idle issue.
