I just built a 12x16 outbuilding that I want to run electricity to. To get to it, I'm goingto have to run 150 or so feet of wire, probably 220 to the building and split it to 110 leads (unless 2 110 leads would be better?. The load there will be a 5hp air compressor, occasionally a 110 welder, and normal shop tools (tablesaw, etc. but never over 1-2 at a time). I will then run a lead from there (off one of the 110 leads) about 100' to put an outlet in the Carport I store my boats in to run a couple lights and battery charger.<br /><br />I plan on putting one of the shop type small breaker boxes in the building. What gauge wire shoud I use for the 220 and 110 legs? What size breaker to use in the house panel? I'll have to double check, but I'm pretty sure there is 60 or more amps of capicity left in the house panel. I will be using conduit to bury it in.<br /><br />I'll have someone with experience connect it to the panel, but I want to get it all buried before hand and ready for them to just hook up.
