Any experience towing with these SUVs?
fishin98
Almost every state in the SOUTH is 70mph...60-65 on 2 lane...Texas is 75 65-70 on 2 lane....BTW...the Durango with the tow package is set up with a sway bar. I recommend A Durango to the OP instead of the JAP JUNK or the over priced/over rated GM stuff...Just my opinion.
cdnNick
So I was looking at the Durango manual and it says to use a WDH for trailers over 3500#.
In my EZ loader manual it says NOT to use a WDH with surge brakes which I have and a swing tongue on the trailer as well. My boat and trailer should be about 3500# or less. Not sure since I can't pull it to get weighed. So I guess I should be ok.
Maybe I am over thinking things when it comes to towing or maybe other people are way more brave because I have seen much larger boats towed by much smaller vehicles.
oldjeep
Almost every state in the north is 70-75 on interstates as well
oldjeep
There are WDH that work with surge brakes, but I am surprised that the manual says that you need one for over 3500lbs, must have a really soft rear suspension. I know that you see many Grand Cherokees towing more than that with no WDH.
cdnNick
Copied out of the manual:
Do not use weight-distributing hitches with surge-braked trailers. Overloading or improper installation of weight-distributing hitches may not let hydraulic surge brake actuators work and the tow vehicle and
trailer may take longer to stop.
Now I know some WDH are not compatible with surge brakes but some are, now another problem is the swing tongue. I don't know if I would have enough room to fit the adapter for a pole tongue between the swing tongue and winch mount. Also I've read that the force the WDH put on the trailer might not be good for the swing tongue. I was trying to avoid the WDH altogether for these reasons.
I wouldn't drive on the highway at 80-85mph on a normal day, I would certainly not be doing that while towing. Highways around here are 100kmh (60mph) anyways.
fishin98
If your looking at the latest GEN of Durango's, I wouldn't worry about the Pentstar 3.6 V6....290 hp...easy on fuel, good everyday grocery getter, and on the weekend pulling the boat to the lake.
Boat Doctor1
Have a 2011 hyundai tucson=(smaller than a santa fe) it tows excellently!! No worry -
Willyclay
Agree! Our son tows his 19ft Ebbtide 4.3L Mercruiser I/O with his 2012 and it does very well. Even handles the very steep ramp where they launch. Good luck!
oldjeep
Sounds like a commercial definition
'Combination of Vehicles.' Every combination of motor vehicle and trailer or motor vehicle and semi-trailer the principal use of which is the transportation of commodities, merchandise, produce, freight or animals." - See more at: http://www.atg.wa.gov/ago-opinions/...ion-vehicles-combination#sthash.NBBUl4Q5.dpuf
bruceb58
Honorary Supreme Mariner
'Combination of Vehicles.' Every combination of motor vehicle and trailer or motor vehicle and semi-trailer the principal use of which is the transportation of commodities, merchandise, produce, freight or animals." - See more at: http://www.atg.wa.gov/ago-opinions/m....NBBUl4Q5.dpuf
On another site it said passenger cars, including pickup trucks, pulling trailers was in that definition. I have towed there. I know its 60.
