any info on the 83 200 evinrude
striper
Does anybody have anything to say about this oldie as it's on a Grady White I'm contomplating buying.
almost retired again
Re: any info on the 83 200 evinrude
Striper,<br /> In my opinion<br />these were very good engines, of course it all depends on how well it has been maintained, and how good the compression,spark and lower unit is now. If all that was good I wouldn't hesitate to buy it if the price was right.
striper
ARA, thank you tons I'm trying to get the lo down on the power plant. They want 8 grand for the whole rig (it's a 20' overnighter) and I know the hull is in exquisit shape,the power plant has some oil residue in the compartment which I would think would be normal for a 2 stroke.My main concern is would it be worthy to have the powerhead <br />rebuilt??? and what should I look for???
Hi Striper;<br />Yes I think that the engine would be well worth while to rebuild especially if this is the first overhaul, however I wouldn't overhaul it unless it needed it. (If it ain't broke don't fix it) Check the compression and spark, spark should jump a 1/2" gap and the compression shouldn't vary more than 15 lbs. between cyls.<br />Good luck, By the way Golden Precision Marine in Eagle Rock, MO. has short blocks for that I think for around 2K
striper
ARA what do ya know about the 89 johnson 235??? I hear they quit making those in 85 is this true??
never worked on one but I can look up the information for you. If you are still here tomorrow I'll let you know.
seahorse5
Those old V6's ran very well but burn more fuel than the later more efficient models. Make sure that 19 year old motor is checked over thoroughly by a QUALIFIED tech. On an engine that old, pay close attention to the insulation and wiring condition.
butlp
I had a 235 Evenrude on a 19' Crestliner and it was a great motor after I rebuit it. I still have the Service Manual and Parts Books if you need them.<br />Send me an e-mail to: jandpbutler@mexis.com<br />Good luck,<br />Peter
striper
Thanks alot LC I'll probably take you up on that. I did find out that the broker was wrong it is an 85 was rebuilt in oct and still has a year warranty on it from the rebuilder which I'm sure will be up in oct. Goin to make an offer on it tomorrow.
butlp
Striper,<br />The Manual and parts book I have covers only the V6 motors so I don't think it would be much good to you.<br /><br />Anyone want a OMC Sevice Manual and two Parts Catalogs for all Evenrude or Johnson V6 150 to 235 motors.<br />They are gathering dust in my den and I would gladly give them to a good home.<br />If you get back to me today or tomorrow I can post them on Saturday when I pass through Chicago Airport.<br />Peter
Salty Dog
Make sure you check the steering arm for rust
jcreech1
LC,<br /><br /> I am interested in the service manual you have. Does it cover 1980 Evinrudes?
