any jet boat guys
hardlearner
was looking for someone who knows berkleys and where I might be able to get some used parts. I have a 21 foot hiwiian with a 355 chevrolet. I need some help with the nozzle as far as some brackets and in need of a driveshaft. Was also wondering if the driveshaft uses studs in the crank or bolts. I have several nozzles but looks like only one will work. The one I have that will work needs to be either helicoiled or welded and tapped which should be no problem but I do not have the bracket for the cable. I can attach pictures if that would help, Also need the fittings for the hoses where the water pump would be and the thermostat. Thanks!! As always trying to work with a budget.
Re: any jet boat guys
Ayuh,.... Greg Shumaker at GS Marine will either have what ya need, or know where to find it...
Good Luck...
Ayuh,... Glad to hear it,... Greg is a Great guy....
