Any one have experience with this SS prop?
Boomyal
walleyehed
Re: Any one have experience with this SS prop?
Boomyal, take a look at the top of the prop forum...I pinned a post on testing this prop.....
"Apollo test results"
Boomyal
Nice survey walleyehed, I guess now the only thing I need to do is determine if there is any benefit to switching to SS.
I had thought my Merc 1-888 prop was a 15.25. I just went out and measured the diameter of a spare but slightly chewed up prop and it only measured 13.5", (unlike my OMC, the hub only shows the pitch, not the diameter)
Looking on the prop chart in my Merc manual, it shows a 15.25" prop for that drive/motor, boat length/weight combo. So I am a little confused now. I'll have to check the prop dia. that is currently on the boat.
Tail_Gunner
RIght now im nose deep in 3-4 blade ss props, i can tell you a 4bl-ss is one smooth machine. It also ( depend's on the style) lift's the boat quite a bit higher out of the water making it smoother on a good chop.
The christmas season is coming and the wife is begining to watch the cash flow with a lot of detail other wise i would be adding a fuel flow meter, it would be intresting to see if it also provides better econ..........:devil: by spring ill get handled.
Umm if you get a 19 the race is on..........8)
walleyehed
the 13.5 diam. should be for 13 spline gearcases, not your 15 spline 888.
Boomyal
Just to verify that I am measuring right, I made a dot on the garage floor. I centered the prop over the dot then ran a square up to the tip of each blade and marked it on the floor. I then took a set of calipers and measured from the dot out to the blade tip marks. That sound good?
I don't know why Merc props don't have a diameter stamped on them, but maybe this prop had been previously repaired and cut down. It is a 15 spline and stamped 21 on the hub but had been a spare prop in the boat when I got it. I will definitely measure the prop that is on the boat.
While I am figuring it all out, hypothetically, do you think there would be any benefit of a SS 15.25 x 19p, such as the Apollo, over a cupped 15.25 x 19p standard aluminum prop?
walleyehed
yes...better efficiency, likely a bit more speed at all power settings while on plane.
Personally, I won't run aluminum anymore unless I'm in 2-3ft water loaded with rocks.
Texasmark
You and me both, bruddah! 8) But I don't need the shallow water nor rocks to deter me. I just ain't a gonna do it.......but there aren't any rocks where I boat so I can say that. d:)
Mark
Sorrento 25
I bought two of the WM Apollos off Ebay to try next year. Heck of a deal!
Boomyal
What does the WM stand for Sorrento? I assume you have a twin drive setup?
