Tafflad
Thread starter- Joined
- Oct 23, 2007
- 548
Just bought a replacement boat - with a 2011 4.3L MPI Mercruiser ... with only 5Hrs on the clock.
It currently has a 4 blade Aluminium 20" pitch prop.
I want to put on a SS prop .... but not sure what one to use ...
On Mercury site the Prop Selector fails with message that boat weight is outside range .... at 3,850lb yet says at top of screen suitable 8650 - 21,625Lb
(As a test I knocked 500Lb off boat all up weight and still get same error - assume tool is broken.)
Looking at options previously I have fitted "High Five", props but maybe a 4 blade is a better option for me.
On the 4 blade props in SS the options are "Revolution 4" or "Vensura"
Also I would have to go up or down 1" in pitch, and SS 4 blades only in odd pitch numbers - so assume I'd go with a 19"
Welcome any advice ...
Boat is a Monterey 194fs ...
alpha I drive (1.62)
incl people & contents weight 3,850Lb
excl fuel (36 gall tank) so total all-up around 4,100Lb
Use is 100% salt water in-shore recreational skiing, boarding, hydrofoiling ... top end not crucial, just need hole shot and good mid range performance.
I do not have option to buy & try ... so need to get choice right.
