rodknocker
Thread starter- Joined
- May 11, 2007
- 16
I have an OLD Evinrude 65 hp 3 cyl. outboard that has some kind of problem in that when you start it up, it idles fine. But when you hit the gas, it bogs down, and will not plane out unless you fiddle w/ the choke. I have cleaned the carbs 3 times, my brother cleaned them twice, but we cannot figure it out. this motor is the one with the electric shift; no gear cable. I changed fuel supply lines--the hose with the pump up bulb on it, as well as the fuel tanks. Fuel pump, possibly????
