JustJason
Thread starter- Joined
- Aug 27, 2007
- 5,392
Trying to help out the folks here.....
Got a 00 Avalon. 3.0L 1MZ-FE engine. 112K on the clock. Heavily neglected.
Runs like a dog. Had a MIL on. Borrowed a buddys lower end scan tool. Got a P0179 code. "bank 1 lean".
Thing is never maintained. (not my car). Figure I'd start off with plugs (believe they were the originals... they came out pretty rough) Fuel filter, air filter, PCV, oil change. Flipping back the throttle plates revealed about 10 pounds of sludge in the intake manifold. So I seafoamed it as well.
It helped a bit, but not enough.
Same code. I don't have a waveform analyzer but I tested the rear (bank 1 O2 sensor *which is really a wideband O2, more of an air/fuel compensation sensor than it is just an O2*)
I have a manual for an 02 camry with a 1MZ-FE engine so i'm hoping the engines are the same. Anyways, That manual has static resitance checks for the O2. Bank 1 O2 fails resistance check and bank 2 passes. I go ahead and replace bank 1 front O2. I clear code, run for 10 to 15 miles. Hard runs, from 0 to 70 at WOT. Its got a little stumble between 2-3K then picks up and takes off. Not to bad of a stumble, but it still should not be there.
So I give the car to the folks and explain to them what I found. They take it for the weekend and right around 150 miles after I give it to them It has another MIL and has a worse stumble.
Scan it again, this time I'm getting a P0171, "system to lean"
From a dead stop. Pressing the accelerator to WOT causes a few backfires that are contained in the exhaust pipe. It stumbles, then takes off. Mid range acceleration is excellent. (probably from the lean condition).
I'd love to fix it for them But i'm a boat guy and not a car guy.
Went to school (and yes finished) for boat engines. But I don't have any training on emission controls and do not fully understand them.
I did find 1 vacuum hose with a small tear at the end. I believe it was attacted to a VSV. (vacuum switching valve). I snipped the end of the hose to remove the split and reinstalled it. And again it's better, but still pops. I spent 2 hours today looking at every intake joint I could for a leak, but I couldn't find one (that doesn't mean that ones not there either) After clearing the P0171 and a couple of hard runs, the code hasn't come back yet but I'm sure it will as it's still not right.
Anyone have any experience or advice on these 6 cyl's they can share with me... I'd Appreciate it.
Cheers!
Jason
Anyb
Cheers!
Jason
Anyb
