Anybody got a diagram of how the cooling system FLOWS for a 1987 EV 90HP ???
bang4dabuck
I can't figure out how/where the water gets to the block/head and then how it flows to the other head. I would guess the water exits thru the exhaust housing.
etracer68
Ensign
Re: Anybody got a diagram of how the cooling system FLOWS for a 1987 EV 90HP ???
I have a 1987 Johnson 90HP, and the way I see it is, the water comes in from the exhaust housing, to the heads, then out the bottom of each head (Port bank, and Starboard bank) through hose ( each side) to the termostat housing. Inside the termostat housing are the two termostats and two springs over the popits, which (popits) open under WOT from high water pump pressure to suppy more water at WOT. I hope this is clear enough.
wilde1j
The OEM shop manual typically has a detailed water flow diagram.
bang4dabuck
I did find it in the manual. Thanks for pointing it out.
