Re: Anybody ID this Flywheel Cover ??
Thanks rodbolt,.....<br />
looks like a 71 or 72 series velvet drive or a jack shaft adapter pattern on the drive side.
What I'm looking to Know is if there's any Commonallity with the different transmissions,+ bearing adapters....????<br /><br />Like when I'm dealing with class 8 Trucks,+ Heavy Equipment, there's a #1 bellhousing pattern,+ a #2 bellhousing pattern.........<br />With this Info, you can install a Cat. motor in a Mack,... or Cummins in Whatever you'd like,...Etc....<br /><br />I need to know if a Merc. bearing adapter would be the same pattern as a Hirth or Velvet drive, or whatever..??....<br /><br />Thanks........
