Anybody remember TC-W oil (no 3...)
SeaKaye12
Hi,<br /><br />When I got my free boat and 1977 Merc 850 earlier this year...it came with a fair amount of ""Old Stock" Quicksilver Formula 50-D oil...and some Penzoil TC-W oil. (not TCW-3...)<br /><br />Anyone remember what changed from these older formulations to what's sold today as TCW-3?<br /><br />I've gone ahead and started to use up what I have...and will continue to do so unless there's some reason to put it aside and go with the new TCW-3.<br /><br />Any comments? Just what we need; I guess...another oil thread :) <br /><br />Thanks for reading, Chuck
timmathis
Re: Anybody remember TC-W oil (no 3...)
It won't kill it should be O.K. TC-W3 is better oil. Tim
seahorse5
IF the oil is still in the original metal cans, hang on to it or check on Ebay. A lot of restorers and collectors are interested in the vintage stuff.<br /><br />Use TC-W3 oil in your motor as it has a lot better lubrication properties and more cleaning detergents than the original TC-W oil from the early '70s.
Solittle
Remember oil is cheap - powerheads are expensive.
joblo33
Are they worth a lot? Do you think I should put my cans on ebay? I have 2 six packs of OMC TC-W in my shop still connected by the plastic rings. They were under my cabin and I didn't want to use the old stuff in my motors.<br />Eric
TOHATSU GURU
I think we still have case of Chrysler 50:1 TC-W lying around.
SeaKaye12
Some of the difference between TC-W and TC-w3 is oriented around lower emissions...and some of the difference is oriented around better lubrication and less carbon build-up.<br /><br />Can anyone go into detail on that?<br /><br />Thanks, Chuck
LubeDude
Yes, use the new TC-W3 oil, and because this engine was ran for a long time on the old oil I would say you would benifit greatly by doing a bood decarb, maybe twice.
Scaaty
I remember buying the old pint six-packs of Merc oil......I'd mix it half and half with -3 until gone. And check ebay.
jjbuoni
After this post, I checked and found that I have I have some older pennzoil and it says TC-W II. Unless I find otherwise, it is for the snowblower and other 2-cycle but not my mercury outboards.
