Anyone ever tried this to get a metal stud out of aluminum?
artificialreef
Hi again folks. Still trying to resurrect my twin 470's. Every dang bolt or nut i try to take off turns to cr##. These are 1983 motors. I found a broken bolt on an aluminum elbow in the exhaust so feel the need to button it up so my gf doesnt die from carbon monoxide poisoning in the cabin.
Its the elbow going way down to the bottom of the outdrive that would require an engine pull to replace. Its the section that houses the flappers. Good thing i looked at it because the flapper was nonexistent. I snaked a magnet down to the outdrive and pulled up the metal retainer. Then shoved a wet dry vac hose down to try to get the rest of the c***.
Anyhow my question is. I drilled out the broken bolt and had to cut off the remaining two bolts at the flange to get the elbow off. Now i have 2 studs sticking up that i halve to get out. I was thinking, i have a cheap hf welder. If i take some copper pipe and hammer it out to a washer, put a nut on top of the copper washer. Being that the elbow is aluminum and the studs are steel. Couldnt i put a copper washer underneith the studs. Disconnect the battery and weld some nuts on the studs and try to back them out?
I will need to create connectivity by tapping a steel nail into the oversized nut with a needlenose vice grip connected to the nut. I will clamp the welder to the needle nose vice grip to create the ground source.
Does this sound doable to get two metal studs out of an aluminum housing, or am i going to kill myself with 208 volts. I am a shade tree mechanic that has done some pretty creative stuff to get things working. But i try to be safe and thorough. (hence sealing the exhaust leak) Thank you for your professional advice in advance.
1983 Tiara
twin 470's
Pete104
Re: Anyone ever tried this to get a metal stud out of aluminum?
Drill, cut, lift & slide. Repeat as needed!
sschefer
You can weld a nut on it. That's not a problem, Aluminum conducts electricity. Shoot a bunch of Blaster on it and let it soak then clean it off, weld a nut on the remaining bolt and it should come out pretty easy. I've done it on Merc mid sections.
artificialreef
Pete, What does that mean? I imagine my biggest concern would be if that nail came loose and created a floating ground to kill me. But if i can just get it tacked i may be okay. Correction, the copper washer goes on the stud under the oversised nut so i dont get slag onto the aluminum.
Pete104
You got pretty wordy & I lost you. I thought you were going after the manifold! LOL
So you've got the flapper section out, right? And you have the intermediate section out, right? The problem is the broken bolts that fasten the intermediate piece to the piece at the gimbal hsg. Right? I'm thinking that those are stainless. Tough to weld anything to, under good conditions! How much material have you got to work with, thread wise? Don't sound like much. How about drilling?
bruceb58
Just clamp onto the aluminum. Not sure what you are worried about.
