Anyone familiar with changing this type of tilt/trim hose (pic)?
R Steele
Is this one single hose? If so, I assume it has to be pulled out of the transom mount to the rear since the straight connector is topside connected to the pump.
The nut on the topside is virtually inaccessible with the engine/flywheel cover in place, so I'm wondering if you can undo the bottom nut on the outside of the boat (which isn't too bad to access) and push the hose upward and into the boat so that you can then reach and remove the topside nut.
Anyone know?
572, DP-C
