On the boat I recently bought I have a 1984 Mercury 9.8 (Comet Lighting) for a kicker / trolling motor which started great when I went to buy the boat...started great (first pulls) on the first two outings...then on the third time out it will just not start.
It has compression (I can feel it) both plugs show spark with my tester...I just put new plugs in and even tried spraying a little gas / oil mix directly into the carb. Still nothing.
I am ordering a manual but I would like to get out and use it before the manual gets here (plus I doubt the manual will help with this one).
I am wondering if there are any electrical or mechanical devices that could need cleaning etc?
Or anything else I can look at or consider to be the problem.
The only known issue with this motor is the bracket that locks the motor in the run position is not releasing / latching correctly. You have to reach under the power head and latch it or unlatch it by hand.
Thanks in advance.
UPDATE: With the brand new plugs in I have primed gas bulb...gave it throttle and tried to start several times.
Plugs are completely dry..is that where the problem lies?
I am very new to all of this stuff still.
Thanks in advance.
