Anyone know what normal compression figure is?
ahm
Anyone know what the normal cylinder compression figure should be for a 1989 80hp 3 cyl Merc o/b? I am getting 110 psi on each cylinder with the engine cold. Is this OK? Thanks in anticipation.
new owner
Re: Anyone know what normal compression figure is?
yes that compression is good. Usually anywhere between 100 lbs and 140 lbs is where you need to be.
12Footer
And the fact that they are all equal is very good.
