apollo propeller small problem
Acuario
Got me Apollo propeller, it come with hub kit. by the way it have a nice highly chrome polish...but I noticed that the at bottom of the propeller is little too long about 1/8 it touches housing when you torque it. I think, if i file the bottom of it will be ok. i just wonder if any one had this problem before.. for some reason on 1991 2050 Capri.
:confused:
Dhadley
Re: apollo propeller small problem
If the prop touches the gearcase then you may have the wrong thrust washer. The prop should not touch at all, it'll be close but not touching. When you run the boat the prop obviously tries to move forward towards the case. If it's touching now it'll dig in a bit more under power. Double check your thrust washer, you may need one slightly thicker.
Acuario
Ty Vm, I guess the kit had the wrong washer.. where i can buy this washer at?
Acuario
It came with propeller when bought it from Iboats the kit was included.
Dhadley
There ya go. I'm sure they'll work with you to get the right one, shouldn't be a problem at all. Nice folks and very willing to help.
Acuario
will contact them ty
