Appleo's 1985 Starcraft Supersport 18 foot - Restoration 2019/2020
appleo
Bow dashboard. 12v cig lighter. tilt trim switch. magnet strip from harbor freight. am i missing anything!
Rikkie
Look like your doing a fine job,what kind of power is it going to get?
appleo
i have a 1986 mercury 70hp
need to find a pair of 14 or 15 foot control cables. i think it uses gen1 cables ?
appleo
Bow deck screwed down today. drilled hole for pedestal base. installed vexilar flasher hatches coming via fedex saturday
Rikkie
Apploe,was all fome on eathe
side stock?or was that added.i have a1981 when I look through ski locker hole I see stirafom prices.or is that the difference between 81 -- 85?and to bilge pumps are you thinking of it being a bad leaker nice to be safe.mine has just Manuel switched I though I was just going change it auto now I think I'll add auto to. Your boat is looking great,wishing you tight lines
appleo
i removed ski locker. they are water reservoirs
Factory foam was
1 under floor left and right side of center trough
2 hidden under gunwale 4”x4” strip
3 a 14” square block under left and right side of splashwell
Factory foam was dry so i kept it.....Added more foam under center floor. new foam it is all white ....
i removed the two blocks under splashwell. replaced one.
I had a few spare bilge pumps so i installed two. each one wired to own float switch and battery
I often leave boat at marine for weeks
appleo
factory foam yellow. added new foam white
appleo
Wise captains chairs. - Anyone ever mount on box vs a pedestal?
thinking outside the box ...lol.
if yes please post photo or advise particulars
GA_Boater
You can do anything you want. Whatever floats your boat.
Build a box with a hinged top or drawer(s), secure box to deck, mount seat with or without swivel, done.
appleo
i have a box. 13 inches high. would need a low profile swivel
appleo
Starcraft Supersport Helm seat height
Rebuilding my 1985 SS 18'
New seating in in order
Trying to determine seat height vs windshield
12" height from floor to seat underside. puts my eyes at top of windshield
Thoughts on where eye level should be?
What was factory seat height and how measured?
Opinions and /or facts appreciated 😃
appleo
Head banging how to use those two captains chairs i had in the barn. pedestals or seat boxes . Decided to split the storage box i made for starboard and use fit the helm chair also
Passenger gets a pedestal which needed trim using my harbor freight 9.99 grinder. 😉
appleo
Photos.
Watermann
Is that OSB? :eek:
fetch
appleo
Winding down.
Made a cover for the starting battery box. and added a dollar store shower rack for the markers bouys
