ShoestringMariner
Thread starter- Joined
- Apr 18, 2015
- 1,605
Hey fellas, I’m trying to figure out the dry weight of my boat as it would’ve come from the factory. I found something on the web that unofficially states an18 foot is roughly 850 pounds. I would have to assume that this is without a motor, battery etc. ( basically helm, flooring, steering, windshields seats etc.)
What I’m trying to determine is whether I can get enough flotation foam into mine that will be enough to prevent worst case scenario of total loss. (Sinking to bottom) The foam that is in mine is totally waterlogged and garbage. I’m replacing with dense styrofoam SM. I’ve done under the floors and 12 inches up the side of the hall for the first 2 feet of the boat so far and I’ve used one 2“ x 24“ x 96“ board. From what I can find each board should support around 160 pounds of buoyancy give or take a few pounds.
I’m doubtful I can stuff this much Styrofoam into my boat. To support my boat, motor, starting battery, trolling battery, trolling motor, anchor etc, I’ll need somewhere in the neighbourhood of 9 or 10 of these boards.
have any of you restore guys managed to cram that much Styrofoam in your 16’ boats?
do you consider the plywood to be neutral weight since Wood typically floats on its own?
