VFDfireman
- Joined
- Feb 3, 2008
- 10
Hey all,
My first time here, and the past Feb. I bought a ~78 21' Glastron with a Aq 170 inboard and a 270 out drive. I bought it as a project boat for $600 with trailer.
The boat is in great shape for the age, all it really needs is carpet and seats refinished and the gel coat cleaned up, other wise it is a rock solid boat and the motor is too.
However, I'm chasing electrical gremlins on the tilt system. I can only get it to go up or down with out a load on the motor (i.e. someone lifting the lower unit). When under load I'm only getting a click from the lift motor when operated by a switch in either direction.
What are the common issues with this unit? Are rebuild kits available? I think it sounds like the motor is weak or shot, any thoughts? Areas that I should be checking?
Thanks
Thanks
