AQ125A E.I. Upgrade
raven1978
Looking for the experts on these engines. I am planning a pertronix upgrade for this engine during winter layup. I plan on doing the electronic ignition upgrade and putting the 40,000V flame thrower coil on it. The existing Napa coil in it says to use with external resistor. Coil + has only one wire running from it to the main harness. I do not see a resistor anywhere tracing it as far as i can see. If a resistance wire was used, what would the resistance equal, 3-4 ohms or.... ? If it is a resistor wire which coil do i use, 1.8 ohm or 3 ohm? If any more info is required just ask.
