Some background information. Boat ran great last fall but I was getting small amounts of oil in the antifreeze. Fast forward to last week and I pulled the head, had it machined and #4 exhaust port repaired.
Today I replaced the head and attached the intake, exhaust, carb and fuel pump to test fire the motor before I screw around with the heat exchanger.
Figured I had lined up the 3 timing marks and tried to start ( no start ). Re-checked the marks and they are all set. Slipped the timing cover on and the timing mark would be appx 0 deg when the bottom sprocket is lined up on the marks.
I have fuel and spark.
Then I popped the distributor cap and it was pointing at cyl #4 ( 180 deg out ) ???
I then started over again and pulled the timing belt and lined up the distributor with cyl #1 and it matched the timing mark
Lined up the top timing mark with the bottom timing mark using a length of rope ( it appears both the cam mark and the crank mark should literally line up with each other with the line passing thru the cam bolt and crank bolt )
I tried a re-start and got a backfire ( figured I am getting closer ). I tried advancing and retarding the distributor but it still wont start.
2x batteries fully charged
I have a good strong blue spark
Fuel is getting in the carb and I tried with starting fluid as well
I spent about an hour getting it all bolted back together and over 3 hours trying to figure out why it wont start.
Any suggestions would be helpful. It must be in the timing somewhere
thx
thx
