Brucetafer
- Joined
- Aug 26, 2010
- 223
been looking all over the net, cant find anything...
idles perfect at 850RPM, timing at 6 bdtc, 205 compression.. still runs rough at 3K - 3400 rpm, cant go over it...
has the correct prop on it, 14-17.
2 things left that i can think of that is stopping the power, carb or timing belt off... dont really feel like pulling everything apart to check the belt, (belt looks great no weather cracks and perfectly square...
anyhow, boat sat for 5 years with a full tank, redid everything, all filters distributor rebuild with pertronix kit, spark plugs, plug wires, starter, ran a seafoam treatment through it let it sit for a whole night with tons of seafoam in her, and still no go...
what should i start with? if timing is off 1 tooth is it noticable?? if not is there a way to check the timing belt with the heat exchanger on??
how hard is this solex carb to rebuild??? i know the air/fuel screw was turned by the previous owner that couldnt get this thing going...
what else should i look for thanks
boat is a 1988 arrowglass carisma 5.2meter..
oh and im at sealevel, monterey ca..
1 last thing, the exhaust flapper blew off when i was running her, anyway to get a new one?? my local shop said i need to get the whole unit... outdrive is a 275.. thanks
