AQ131c Carburator jets
neilewins
I have a citation cuddy cabin with a volvo AQ131c conected to a 275 out drive. it is very under powerd and bogs at low throttle. i have checked many things but now need to check the jet sizes.The carb is a webber twin choke 32/36. can any one tell me the jet sizes for this carb please? Also what size engine is it 1900 or 2.2.
Cheers
Neil Ewins
Don S
Re: AQ131c Carburator jets
It's only a 120 hp engine (2.3L), what size boat do you have.
When was the last full tuneup, including dwell and timing reset, and a compression test.
May also be the carb needs disassembled and cleaned.
neilewins
The boat is 19ft and can eventualy get upto full revs. i have replaced everything on the ignition side and rebuilt the carb. just trying to eliminate everything the boat was not previously owned by a mechanic. It feels like a carb setting or air leaks. My next test is a compresion test and maybe head off and valve lap! So if any one has a manual and can tell me the jet sizes it is one more thing to eliminate
Thanks for the help
Neil
sqbtr
You will probably have to get a hold of webber for the jet sizes as 131's originally came with a solex carb.
