Re: Aq131d cylinder head question
Well tried to adjust the carb air mix, and turn dist. No joy. Have the battery recharging as I drained it trying to start it all day. All timing marks are aligned correctly, plugs are new and properly gapped. Carb is a rebuilt carb from a reputable dealer, distributor has an electronic ignition (hotspark). I got close to it starting, but then nothing, it starts after giving it some gas then dies. I pulled the distributor out completely and placed the rotor pointing to the number one plug on the cap and then rotated it clocwise 1/8 of an inch and then placed it in the block, it wanted to start, i moved the dist back and forth and kept trying to start, it will crank, fire and die, then depending on which way I move the dist it will just crank and not fire. I realize this thing has no choke and is hard to start when cold, but this is rediculous. I have been spending so much time trying to fix the issue and get it to crank and run with no luck. Not sure what else to do, the cylinder head is rebuilt, the carb, new fuel pump, tank, lines, plugs. I can't believe that it is this difficult to time the engine. I have great compression, spark, and fuel. I had it running the other day, but once it stopped, I couldn't get it restarted. So frustrated. I timed and retimed this thing so many times with no luck. Any other ideas would be appreciated. Thansk. Edit Post Reply Reply With Quote
