Aq151, New head gasket and bolts, confused about torque.
rbuljo
Replacing the head gasket and bolts on a aq151a, the Volvo manual says
20nm - 40nm then 120 degrees.
The instructions that came with the new head bolts say;
20nm-40nm-60nm,
then loosen 90 degrees,
60nm then 90 degrees.
Do they differ in specs cause of the bolts are new?
rbuljo
Re: Aq151, New head gasket and bolts, confused about torque.
anyone?, standing in front of it now hoping to put it together tonight. :)
Alan Lloys
I know you are probably already done with this project.
But anyway I would go with the instructions from the bolts. Often times they learn new things over time and change the procedures. They may also change the heat treating of the bolts which will have an impact on how they stretch and should be torqued.
rbuljo
hi, thanks for your reply. i did this a while ago. followed the instructions from the workshop manual.. I feel they got pretty darn thight though :)
