Hi, I wonder if some one can help?one of my engines AQ151c is overheating, I thought head gasket but no I put a tester on several times and it is ok,changed the thermostat, serviced the raw water pump, took the heat exchanger off and took apart and cleaned, checked the timing and it is about10-15 past TDC and should be 6 BTDC will this make it overheat? there is no adjustment on the distributor so will have to take out and reset. she would be fine at 6-10knots but at 17-27knots within 3mins overheated but now she gets hot at low speed and cuts out.
