VFDfireman
Thread starter- Joined
- Feb 3, 2008
- 10
I have problem with the idle on my AQ170. When the boat is cool, the boat idles good.
After 30 to 40 mins. of hard running, the boat will not idle well, and I have to take the boat out of gear to advance the throttle enough to keep it running.
I have also noticed that if I open the dog house, the boat idles really good when hot. I do have a bilge blower, and it does work, but I'm not sure about the airflow.
Does it make sense to add another or bigger blower?
My starting problem is wierd. The boat acts like it has a weak battery when the ignition switch is turned. It will just click. If you keep trying, it fires right away without issue or weakness. I have a new starter and new battery. Ignition switch is also new. Any thoughts? Could it be the neutral switch? If so where is it located on a AQ170 / 270? Other culprits?
Thanks
Thanks
