AQ170C Exhaust Manifold Repair Pics
heryrg2711
Hey guys. Last week i took off the exhaust manifold and noticed a decent size hole on the bottom, check the pics. I took it to a welder guy last week and he said he could fix it for about 150. Well i call the guy today and now it will be another week (he's out of town for couple days) and about $250 to fix this. I don't really wanna spend this much on this.
I was thinking of using some sort of high heat epoxy/bondo, feasible?
Around what temps do you think the exhaust is at or around that place in the manifold?
Any suggestions on how to fix this, besides welding?
Just a thought, i think i might try to take the end off(part with the hole), then i'm gonna try and find the epoxy which needs oven-cure, any thoughts?
RogersJetboat454
Re: AQ170C Exhaust Manifold Repair Pics
Welding cast iron is difficult enough. Welding rotten cast iron may be near impossible. Epoxies may work for a while, but will eventually fail.
You can get a new elbow for surprisingly short money;
http://www.jmsonline.net/volvo-penta-exhaust-riser-831163.htm
I would scrutinize the manifold with crossed fingers. If it's rotted out, the cost of a replacement exhaust manifold for this engine could very well be more than your boat is worth.
http://www.jmsonline.net/volvo-penta-manifold-exh-856095.htm
heryrg2711
Thanks Rogers. I'm going to patch it up for the rest of the season with PC Farenheit epoxy which works with temps up to 500.
Next spring i'll buy a new elbow.
wellcraft19
A couple of other sources as well, although I have not seen the elbow:
In Canada (prices in USD) http://www.manifoldwarehouse.com/mes/mgr?brch=home
In Finland (prices in Euro, seem to be the same parts as above though): http://www.marineparts.fi/en/Spareparts/Volvo-Penta/Engine-parts/Products/Exhaust-manifolds-and-accessories/19333-Exhaust-manifold-Volvo-Penta-6-cyl.-B30.html
In Sweden (a low low price in SEK, but availability in indicated to "spring 2011"): http://www.bilallt.se/MARINDELAR.asp
