quintonwatts
Thread starter- Joined
- Feb 2, 2013
- 33
Symptoms:
new engine block with 30 hours
- boat running fine
- anchored for an hour
- ran in gear at tickover for 45 min on river
- revs faltered, gave a touch more throttle
- revs climbed a little, struggled and died
- no re-start
Following day
- engine started fine
- in neutral to build revs
- struggled for about a 30 sec at 1500 rpm
- died
- no re-start at all
Possible verdicts?
- bad fuel...fresh full tank from reliable source already half used
- choke locked on...ruled out by engineer
- faulty ignition module...verdict from engineer (I trust him so do take his word for it)
Problem
- ignition module no longer supplied by Volvo Penta (pt 855706)
- advised may require complete new ignition setup at some expense
Anyone got any advice on...
Whether this part is still available in the UK
Whether an alternative supplier can be used (Engineer mentioned Mallory?)
Cheers, Quinton
- boat running fine
- no re-start
Following day
- died
Possible verdicts?
Problem
Cheers, Quinton
