aq211a with 290sp lift cylinder replacement
jfalco
just ordered the new trim cylinders for my outdrive but i was not sure what else i should replace while outdrive is off, i ordered new exhaust bellows, new ujoint bellows and new intake water hose, should i order anything else i want to do this one time, thanks, also any tricks to make this job easier, the bolts holding the lift cylinders inside look like they will be alot of fun to remove, their in good shape but any advice to make this job easier will help, trying to beat the cold weather, thanks!
Walt T
Re: aq211a with 290sp lift cylinder replacement
Replace the nipple housing and gasket the water hose connects to while it's off.
jfalco
thanks walt
