AQ270 exhaust clearance
snobdr
Lets try this again as it is specific to the drives
I put a new long hub prop on my AQ270. the blades are 1/8in off of the exhaust duct. Does anyone know if this will be a problem or is running a similar setup 270 or 275 without problem.
diesel1960
Re: AQ270 exhaust clearance
I do have same set-up ,never have a problem,just make sure you secure the prop cone nut,otherwise you will need new exhaust mouth and new prop .
snobdr
Thanks diesel. I thought there would be a little more responce on the issue though.
Don do you have any thoughts on this? Id hate to put a new prop on only to have a problem. Id use the old ones but both that i have are pretty far gone.
