hitest1024
Thread starter- Joined
- May 5, 2009
- 24
So, I have a 85 Bayliner 1950, with an AQ125b and an AQ270 outdrive.
Last week, was having a wonderful weekend with the girl when I hit a 2x8 while running at a fair clip. It sounded like it popped the drive up, but low after powering down and checking it out, everything seemed to worked fine. Long story short, looks like it won't trim up now (even though the trim motor works back on land and the trim light indicates trim up- the outdrive doesn't move...)
The motor works, and the thrust plate moves up and down (from outside the boat.) But it looks like there's a metal rod (the thrust rod?) that's broken off directly below the thrust plate. (It runs down to the bottom of the drive, and ties onto a horizontal crosspiece.)
I have the Clymer's manual, and have searched the forum but haven't find a good diagnostic procedure anywhere- they all deal with the solenoids and electrical parts, not the mechanical parts outside.
The strange thing is I can't even lift up the drive when the tilt is trying to push it up and the thrust rod is pushing down.
Anyone have any thoughts? I'm pretty good at taking things apart and replacing broken parts (just did a head gasket change on my truck with just some written instructions.) But can't guess where to start with this thing. Maybe the marina is the quickest way out?
(Have a picture of what I can see is broken, but can't get to upload at the moment...)
(And yeah, I circled back and picked up the two pieces of 2x8 so no one else would hit it...)
Thanks all- grateful for any thoughts.
