- Joined
- Jul 23, 2011
- 52,351
Ok, so now the boat is in Florida with me. I have to clean all the road grime out/off the boat as well as take care of a few things prior to dropping it in the water.
one of the things that I will be doing is installing a heat exchanger. I contemplated a half system, already went the thought process of a V104 SJE kit, however there is no overhead capacity in the HX according to San Juan.
A custom HX would be required. So I called my former employer down here and am now looking at a custom HX,
however going to go with a full system since I would rather just replace risers than complete exhaust manifolds Having a custom 5 x 22 4-pass system built. It will have some room for tweaking the motor a bit more.
here is the dilemma. From what I can tell, the VP risers for the 80-93 V8's did not have a boss for plumbing the HX seawater discharge to. A block-off plate will be easy (have access to laser and plenty of 316L)
Is there an aftermarket riser that has a boss cast in place for plumbing? The Osco manifolds appear to have a thicker flange that may work, however I would like to find a set of risers that have a boss specifically for the purpose of plumbing.
CMI's are still a thought, however that will have to wait until spring.
