FOuR BuOYS
Thread starter- Joined
- May 11, 2008
- 20
Here is my problem, we have installed a rebuilt 5.7l motor, the leg is a Volvo Penta AQ280. We got everything back together but now are thinking about alignment. First thing we "did not" use the 884502 tool to check the clearances. However we did not adjust the motor mount on the old motor. We just unbolted it from the old motor and bolted it back onto the new one, putting it back in the same bolt holes. So I am think that we are probably pretty close.
The one issue we did have was getting the top of the 280 leg U-joint back together. It took a little bit of grunting and a wack on a wooden block. Is this a normal process or would the small missalignment casuse this.
I plan is to remove the top of the leg and start with the alignment tool and try again. Will it need a wack???
Thanks
Dale
Thanks
Dale
