arcing battery post
JC1933
Hi guys,<br /> I think i may have a problem, whene i hooked up my boat battery there was an arc at the post whene the second cable was connected all switches wer off.It's been a week since battery has been in boat and it seems to be full charge, is this normal? thanks J,C, :confused:
jtexas
Re: arcing battery post
No, definately not normal, unless...you reversed the polarity. Happened to me once.
Silvertip
If you have a clock, radio with memory, automatic bilge pump, any of those may draw power when you made the connection.
JC1933
Thanks a lot guys for the reply. this set up is on a single battery setup,does this make a diference? J C.
JC1933
thank upinsmoke. yes i have a cd player with memory and clock. J C.
Silvertip
They don't draw much power but you would notice a little arc. If the arc is more substantial, listen for the bilge pump. If its running, the float switch may be stuck.
